REDUCING ELBOW
REDUCING ELBOW
narsimhamurthy21
Message 1 of 11
REDUCING ELBOW
narsimhamurthy21
unable to draw reducing elbow in Revit I am tired of changing the welded generic family connection size but its changing at both the sides
I want one side of the elbow it should be 150 dia and another side I want 100 dia is there a welded fitting family that supports this change.
please let me know how to fix this in the elbow family
Replies (10)
Message 2 of 11
iainsavage
Sounds like you need a blend with two different diameter dimensions/parameters.
The standard elbow will probably only have one diameter parameter which is automatically read from the pipe diameter.
Message 3 of 11
iainsavage
Swept blend
Message 4 of 11
aeidAEEEF
I think you have to assign one of the connectors as primary. see below.
Please mark as a solution if this helps.
Message 5 of 11
iainsavage
Standard elbow families are usually just a sweep with only one pipe diameter/radius parameter driving the geometry.
A sweep can't have different diameters at opposite ends no matter which connector is designated as primary.
Swept blend with two different pipe diameter/radius parameters to flex each end separately would, in my opinion, be the solution.
Message 6 of 11
narsimhamurthy21
Hi. Can you share the family which is working for you for this?
Message 7 of 11
aeidAEEEF
sure. here's
Message 8 of 11
iainsavage
Here's what that looks like when you reduce one of the connection sizes.
Message 9 of 11
iainsavage
here's a link to a victaulic fitting which you could edit to suit your needs (probably just omit the collars).
It uses a swept blend.
https://www.bimobject.com/en-us/victaulic/product/victaulic-019
Message 10 of 11
aeidAEEEF
you are probably not editing it the right way. if you have seen I've posted a picture of it when reduced and was not as your post shows.
Message 11 of 11
iainsavage
I changed one of the connection diameter values. How else would you edit it?
Here it is in a project. Just doesn't look right. From the parameters it looks like its a Geberit press-fit bend that's been modified.
I strongly suggest that a swept blend would be the way to go or use an appropriate family as the starting point such as the victaulic one linked above (which uses a swept blend).
