Rectangular Duct Fitting With No Set Angle
fgleason36CXH
fgleason36CXH
I'm looking to find/create a rectangular duct transition that doesn't have a set angle.  I'm basically just trying to transition a duct from one size to another over an extended piece of duct work. All the pre-loaded rectangular transitions have their own set angles (15,30,45,60) and don't allow me to change the lengths of the fittings.
RobDraw
Are you sure?
Rob
fgleason36CXH
That fitting didn't work the way I want it to. I'm trying to recreate the attached ACAD screenshot in Revit. The circled area consists of the transitions.
Edit: Nevermind I got it. Thank you!
jkhounemany
what was the solution?
RobDraw
The one with the green check mark.
Rob
jkhounemany
I was having this issue. I had all the angles shown in our Fitting Types, but after selecting any of the angles, no update or change occur.
After I reloaded the Duct Fitting from Revit's default families, and Overwriting Parameters Value, I was able to fix.
Hope this helps anyone else.
