Connect 2 switches to a light
will.wydock
will.wydock
Dual light switchingDual light switchingI know this question has been asked multiple times over the years but has Autodesk officially announced that you are able to connect 2 switches(switch ID's) to a light fixture? In the past I was under the assumption that they had not introduced this ability yet. While using Revit 2019 I found that was able to apply 2 switch IDs to a light fixture and tag it. As you can see from the image to the left, outside of some tagging inconsistency it was able to tag correctly. What i am finding though is that in some models I can get the model to do this while other models it  only allows 1 switch system. I tested this in 2018 and 2020 and could not reproduce this.
I am not able to upload the rvt model to the forum so you can download the model i worked in here
https://genesispa.sharefile.com/d-s714e8f0ce6b42baa
Any insight is greatly appreciated.
s.borello
See link below... I think it may help you achieve what you want to do.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/c4f...
