Rebar in 3D
Rebar in 3D
Message 1 of 8
Rebar in 3D
is there a way to set rebar to look like solid in 3D view? I checked "as solid" but it steel looks like wire!
Regards!
Replies (7)
Message 2 of 8
HermanSolomon
Hi Mark,
For the rebar to be solid in a 3D view, you will have to change both the View Visibility State to Solid, as well as change the View Detail Level to Fine.
Hope this helps!
http://revitrecess.blogspot.com/
Message 3 of 8
debimmanager
HI @Anonymous
Thank you!!
Deivis E.
BIM Manager
Message 4 of 8
Thank you!
Is there a way to make bars solid in 2D layout? It's ok when I scale to 1:25 but when I have to print details in 1:5 or even 1:10 than I'd prefer them to be solid.
Regards!
Message 5 of 8
How did you manage to get colored baras in 3D?
When I select "consistent colors" in visual styles I get this:
Although my layout looks like this:
I expect to see same colors in 2D and 3D!!!???
Regards!
Message 6 of 8
debimmanager
Maybe if you want to see colors in bars to say something, so you have to select "realistic" in visual style, and then you should have made a duplicate before.
Thank you!!
Deivis E.
BIM Manager
Message 7 of 8
Thank you for your time!
I selected realistic in 3D view but all bars look like rust (all bars are brown). I would like to have same colors as in 2D layout? Do I have to manually adjust something or can it be done all at once?
Message 8 of 8
debimmanager
You're welcome @Anonymous
Try this,
Thank you!!
Deivis E.
BIM Manager
