RCP Component not showing up in view
advandes
Advisor Advisor
Message 1 of 10
advandes
Please see attached PDF views. I have a family  that I downloaded from a vendor that after being placed on the ceiling grid does not show up in the Ceiling Plan like the other components do. You can see in the pdf section view that the item is in the correct location.  All visibility graphics components are turned on. I thought that it could have something to do with the view depth, but I do not understand how the RCP view depth works, so I have left it as the default created it... Thanks for any help.
AAG
Advance Design
Replies (9)
Message 2 of 10
L.Maas
Maybe you can post part of your project or post the family so we can have look how it is created.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 10
RobDraw
It could be one of a number of things. Probably not view range. Post the family.
Rob
Message 4 of 10
robert.klempau
Hello @advandes,
it could be a number of thinks:
If that does not help please upload the family to this post so we can have a look at it.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 5 of 10
advandes
Ok I am posting the family.. Thanks guys!
AAG
Advance Design
Message 6 of 10
advandes
BTW
This is the one I am using in the model:
Fan-Filter_Unit-Envirco-Mac_10Standard-Original23.63"(600)x47.63(1210(Original Alum
AAG
Advance Design
Message 7 of 10
robert.klempau
Hello @advandes,
I checked the family and all looks fine in My project.
In the Mechanical Equipment family, there is a sub Category "Fan Unit" added to the geometry of the family.
Did you check if that subcategory is turned on in you Visual Graphics overrides under ME?
Is the family placed on the right Phase?
It is a face based family. Did you put it on a ceiling or a Reference Plane?
This is how it looks like if you load the family and place it on a Ceiling. (Place on Face)
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 8 of 10
advandes
The Fan Unit category is turned on.
The Phase is correct
The unit is placed on the ceiling with "Place on Face". You can see it when placing, and then it disappears along with the Warning "None of the created elements are visible in RCP...."
Should I create a Reference Plane for placing this family?
Thanks for the help!
AAG
Advance Design
Message 9 of 10
RobDraw
Any filters?
Are you using worksets for visibility?
Rob
Message 10 of 10
advandes
There were filters applied to the view which I did not know existed. These were created in an earlier version of Revit. Good thinking.. thanks a lot for the help!
AAG
Advance Design
