The most RIDICULOUS error message ANY piece of designing/architecture software can give.
If i need to draw something smaller than 0.8mm i should be able to do so!
I get this message waaay too often when creating a generic annotation. It makes no sense AT ALL that Revit wouldn't allow me to draw a circle of 0.7 if i NEED it....
P.s. Make the circle 0.8, then resize it 0.7, that works... what is the point of the given error message then!
Please just remove this error message, if people want to make something as tiny as 0.005 mm they need to be able to do that.
Solved by m-de-lange. Go to Solution.
If you were paying attention during your training, you would know that Revit has limitations in this aspect. Tbere is a minimum and zoom level also can limit how small you can go. Once you understand that, your frustrations will go away. If you can't understand that, maybe a different platform is in order.
If you are demanding a new feature in the program, there are much more appropriate forums for that. This is a user help forum. The complaint department is down the hall and to the left.
Good luck!
The most ridiculous and nonsensical limitation i've ever come across in any software package.
It makes sense to you that I can't instantly draw a circle of 0.7mm but instead I have to make it 0.8 or bigger only to resize it down to 0.7??
Right.
I don't know what your problem is. It is a documented limitation of the software. You should know this, If it's not acceptable for you, use a different program.
Good luck!
