Publish to NWC Add-In for Revit 2024
paul.eterovichY6MNN
Message 1 of 18
paul.eterovichY6MNN
Where can I find the installation files for this? I already have the Navisworks Exporter Add-in added but I want the Batch Publish functionality of Publish to NWC. It seems to be missing for Revit 2024?
Revit 2023:
Revit 2024:
Replies (17)
Message 2 of 18
L.Maas
Have a look at this page https://www.autodesk.com/products/navisworks/3d-viewers
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 18
paul.eterovichY6MNN
Thanks, I have installed this but for some reason it does not include the Batch Publish functionality. I have read online that I also need to install the Publish to NWC Add-In on top of the Navisworks Exporter above but I cant find the Publish to NWC Add-In.
Message 4 of 18
DarrenP
you get the add in from your Autodesk Account
DarrenP
Message 5 of 18
paul.eterovichY6MNN
Could you let me know where? I can not find it.
Message 6 of 18
ennujozlagam
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-8784E553-5742-4C50-99A3-F1E93B07DD88
Message 7 of 18
paul.eterovichY6MNN
Hello all, thanks for your help so far.
I have already installed the Navisworks Exporter from the https://www.autodesk.com/products/navisworks/3d-viewers page.
However, I do not have the Publish to NWC button that I do when I did this process for Revit 2023.
What I see in Revit 2024:
This is what I see in Revit 2023:
Have I missed a step? Do I need to install some other Add-In? How do you batch publish NWCs from Revit 2024?
Message 8 of 18
DarrenP
Read my reply
DarrenP
Message 9 of 18
paul.eterovichY6MNN
I don't see where I can "get the add in from your Autodesk Account"
I can't find it here:
Autodesk App Store : Plugins, Add-ons for Autodesk software, AutoCAD, Revit, Inventor, 3ds Max, Maya...
and I cant find it here:
Autodesk - Account
and since Autodesk Desktop App has changed this is all I see there at the moment:
What is the process to get it and where from?
Message 10 of 18
paul.eterovichY6MNN
Ok. I found it here:
Message 11 of 18
ennujozlagam
download from here
mine before
now after installation
Message 12 of 18
paul.eterovichY6MNN
Only installing the Navisworks Exporter did not work for me. See above.
Message 13 of 18
fabiosato
Try to change to a 3D view.
Fábio Sato
Message 14 of 18
paul.eterovichY6MNN
The answer is that the Publish to NWC Add-In also needs to be downloaded. This is how to do that:
  1. Go to the Autodesk Desktop App or visit the Autodesk subscription site (manage.autodesk.com).
  2. Log in with your Autodesk account credentials.
  3. Locate your Revit version in the list of products and services.
  4. Click on "View Details" for your Revit version.
  5. Navigate to the "Extensions" tab.
  6. Find "Publish NWC Add-in" for the Revit version you're using (e.g., "Publish NWC Addin 2023 for Revit 2023").
  7. Download the add-in and follow the on-screen instructions to install it.
Publish to NWC button is missing from the Add-ins tab in Revit (autodesk.com)
Message 15 of 18
fabiosato
Usually, after installing the plug-in, you can go to File / Export and you will find the NWC export option.
Fábio Sato
Message 16 of 18
paul.eterovichY6MNN
Yes, but the Publish to NWC add-in needs to also be installed to allow batch exporting of NWC files.
Message 17 of 18
sn32MUK
Community Visitor
Community Visitor
Message 18 of 18
gaolad99
Community Visitor
Community Visitor
thank you😀😁😃😄
