Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Properties Guru
3 REPLIES 3
revitworkbench
443 Views, 3 Replies
Properties Guru
Hey so I am trying to export my revit model to navisworks (.nwd for view on line), but some items (like my hangers) are not having there properties transfer through. Most of my families used to have everything that was a parameter show up (maybe it was just shared parameters), but now it seems like families do not display their parameters at all. However, I am unfamiliar with navisworks properties, so if someone could please enlighten me on what I need to do or change in my process. Right now, my process is external tools->Navisworks (.nwc), Navisworks-> (.nwd), -> online viewer. But the information is getting lost or falling through the cracks. Please help, thanks
3 REPLIES 3
I found the following forum thread with a similar issue:
Revit to Navisworks Element Parameters Lost
Does the solution in the link above work for you?
Lance Coffey
Technical Support Specialist
That doesnt seem to have any effect at all. 😞 any other ideas? thanks!
What different levels did you select elements at, and what different properties did you find?
Lance Coffey
