problems with lighting power density calculations
JustinBrown8567
JustinBrown8567
I am having trouble getting my lighting power density calculations to work from a new project template I'm working on.
The Actual Lighting Load gets calculated but the Actual Lighting Load per Area does not.
this is how all my electrical connectors are set up
I am not using the default Apparent Load because the wattage is a calculated value driven by fixture length (when using linear fixtures).
I have done this successfully previously w/o issue.
As an experiment, I went back to the default Apparent Load and it still did not work.
here is how the family type parameter is set up
so I'm not sure what's happening. Any ideas?
I was just about to roll out the new template too!
thanks,
Justin
JustinBrown8567
the culprit was Load Classification; the load class for lighting in spaces was set to none
