Problem with Y junction flow
marco.defina
marco.defina
i have this situation:
I Have one duct with flow 40000 m3/h, i need to separate in two ducts for the Fire damper, after i need to return in a single duct with the same junction.
How i need to set the connector in the family? I receive everytime 0 of flow.
I setted so:
Duct Junction
Global
Bidirectional
Flow 2 on the little connectors
Flow 1 of big connector = Flow 2 * 2
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
RobDraw
That sounds like it should work. Maybe you need to make that second Y a piece of equipment in order to recombine the air flows. Just a WAG.
Rob
marco.defina
It doesn't work...The three connector are setted on calculated...
marco.defina
No one has an idea?
fabiosato
I made a quick test, seems that you will need two fittings, one for splitting and another for joining, with different settings.
Fábio Sato
