Problem with Revit Model Checker
Kai.KoffmaneEWRR9
Kai.KoffmaneEWRR9
I have a problem with the Model Checker. I want to try a test with a new project but my results are alway blank and I dont know what is my problem. Can someone help me?
This is my result and this is empty. I have a new project and I have nothing in. Only some families and the worksets. So its a small file and I get always this message
I use the Revit Model Dashboard.xml for the Model to export a Excel File and in Power BI I use this File to load my excel sheet Revit Model Dashboard 20220202.pbit
Maybe someone have the same problem and can help me
L.Maas
I am not familair with creating PowerBI dashboards. It seems the model checker is pulling data and exporting it to Excel ok. Therefore I am thinking it is a PowerBI issue. I expect PowerBI can not find the relevant data to create its dashboard. So it seems more of a PowerBI issue then a Revit issue.
Have you looked at the BIMinteroperability website? It has documents, sample files (model checker & powerBI) and video tutorials how it is supposed to work together. Maybe that can help.
I did a quick check on an opened almost empty project in Revit 2022 and used your pbit. Got results
With your excel it generates error. I expected it has something to do with formatting (number and dates).
(An often overlooked issue in programming)
For example if you compare our excel files.
So I changed the date in your file to:
Then powerBI again and voila
Louis
Please mention Revit version, especially when uploading Revit files.
riveronicolasezequiel
Hello!
I'm joining really late on this post,
I noticed that the file size on the dashboard has a wrong format, it's like is reading the value on KB and not MB.
Do you know how we can solve this?
Thank you!
