Problem with pipes quantities.
When I export the quantities to excel the diameter changes.
REVIT
EXCEL
Thanks for the help. 😄
check the settings both in revit and excel about the units.. It's related..but check also the number of decimal showing up in excel ...the problem is only in the lines with 4 as denominator..it's seems strange because the other are correct..check if excel sees the inches in the correct way
