Plenum Boxes inserting in the incorrect orientation
sean_lawrenceVQH3G
Observer Observer
sean_lawrenceVQH3G
Observer
Observer
I am using Revit 2022 and modelling using Fabrication Parts, using the V7.06 Data base.
when i insert a plenum box from the "HVAC General Supply" "Grille Box Variable Hole"
(yes it is a floor plan) it was working previously, but i have somehow changed a setting while creating custom plenums....
it inserts looking at the "Back" of the plenum as opposed to the "top".
How do i change this?
2024-01-17 15_33_03-Autodesk Revit 2022.1 - [Project1 - Floor Plan_ Level 0].png
Ghernandez
Sean
Try using the Ctrl+Spacebar together to rotate the Grille to the desired direction.
Let me know if this helps.
Gabeh
