Revit MEP Forum
Piping through cable tray
3 REPLIES 3
451 Views, 3 Replies
I am struggle with putting cables (pipes) through cable trays. I have a lot of problems with connection two section on different height - when I trying to connect those pipes I always get error. Do you have any fast and easy solution for me?
3 REPLIES 3
fabiosato
One possibility is that the height difference is small, usually I make it bigger, connect and return to the position.
Fábio Sato
Kelsey.S
Hi @Anonymous,
What error do you receive? This could give us a hint as to the cause of the issue.
Please mark any posts that help with "Accept as Solution" and thanks.
Kelsey Skaug
Autodesk Technical Support
Kelsey.S
in reply to: Kelsey.S
Hi @Anonymous,
I am just checking back to see if the replies to your post have been helpful regarding your question.
If they were, please consider clicking "Accept as Solution" so that other members of our community can easily find it and benefit from it.
Thank you!
Kelsey Skaug
