Pipework/Ductwork disconnected from a Network When used Move Command
Sujan.Maharjan
Sujan.Maharjan
I'm having an issue with Ductwork/Pipework. When I use the move command with Ductwork/Pipework, the object gets disconnected from the network. I have explained the problem in the attached short video as well.
Any help would be appreciated.
"Revit Lies in the tension between what we want to do and what can be done!"
iainsavage
I haven't watched your video but are any of the elements pinned?
Tommy_S
Have you tried it in a regular plan view? Moving piping in a weird angled 3d view is usually not a good idea.
RobDraw
When you are using the move command, you have "Disjoin" selected.
Rob
viatechnik_viettranduc
thanks you! I have the same problem , now the issue has fixed
