Issue - Menu dropdowns when using different resolution monitors
matthew.shultzSZQLZ
matthew.shultzSZQLZ
Has anyone else had this problem? When trying to change parameters with dropdowns in properties, while a revit window is open on a 4k screen, the dropdown doesn't display. The main monitor is 2k resolution. I have the keynotes open as a separate view on my 4k screen. If I drag the keynotes back onto my main monitor, the problem resolves. Same thing if I drag it onto the other 2k screen.
fabiosato
Unfortunatelly Revit does not work very well with 2 monitors in different resolutions, I face the same problem.
But I use the 4K monitor as main.
Fábio Sato
