Pipe Weights (per metre)
sagnewYUXLR
Message 1 of 12
sagnewYUXLR
hi there,
are there anyway of getting pipe weights for pipe types families?
we would like to add weights to our pipe spools but there aren't any weights in the families or the fittings?
many thanks
Replies (11)
Message 2 of 12
Kevin.Lawson.PE
That data is not included in out of the box (OOTB) Revit, you'll have to add it. Do you just want the pipe weights, or do you also want the fitting and specialties (valves, ect.) weights as well?
-Kevin Lawson, PE
www.rippleengineeringsoftware.com
Revit heating and cooling load calculations in one click!
Message 3 of 12
sagnewYUXLR
hi there,
it would be a total weight (pipes and fittings) we dont put valves onto our spools.
i have begun adding the weights to the fittings and will add a shared parameter to allow these to be scheduled out.
where do i do this to pipes which are different types of families from the fittings?
many thanks
Message 4 of 12
For pipes you need to create a Unit Weight parameter and enter the weight per unit length (for example, 5 kg per meter) for different pipe types from the pipe manufacturer (or just google them).  Then create a calculated value parameter Weight = Unit Weight * Length.
Message 5 of 12
sagnewYUXLR
thanks.
revit/autodesk is it possible you could add weights to the system families in the next release? many thanks
Message 6 of 12
Kevin.Lawson.PE
Create a shared parameter:
then add a project parameter to pipes.
Manage tab-> project parameter -> shared parameter and check Pipes.
Then create a pipe schedule and add a calculated Mass parameter length * pipe weight per foot.
-Kevin Lawson, PE
Message 7 of 12
sagnewYUXLR
thanks so much for this, its much appreciated. it's just a pity the weights aren't part of the pipe properties and require to be manually entered. do you think autodesk will add this in future releases?
Message 8 of 12
Kevin.Lawson.PE
Not likely,  I think Autodesk realized there are millions of different components that go into buildings and they don't want to be responsible for tracking down and maintaining every single piece of data, so managing the content is left to the user.
-Kevin Lawson, PE
Message 9 of 12
sagnewYUXLR
even adding a table in here for weights or somewhere. would this not be possible? even if the data has to be entered mnaually etc?
Message 10 of 12
rajesh_thakurSKQBZ
Community Visitor
Community Visitor
Hi, I need the formula for pipe weight
Message 11 of 12
t_mccusker
Where do you add the unit weight parameter?
Message 12 of 12
Add Weight per Unit Length as an Instance Number parameter:
Add Weight as a Calculated Value parameter:
