Pipe tapping form main pipe
Hi every one,
I am trying to create a welded tapping from the main pipe. When I am joining tapping pipe perpendicular to the main pipe, Its converting into TEE. But I want a The pipe should connect with weld on the the pipe surfaces. So, to over come this problem, I want to create a family so that the created family can be place in the pipe surfaces.
Please help.
Thanks in advance
fabiosato
First you have to create a pipe fitting with part type equal to spud - perpendicular or adjustable.
After that in the pipe type property window, in the routing preferences in PREFERRED JUNCTION TYPE select TAP, the on JUNCTION section load your tap family, remember to set up the min size and max size.
Fábio Sato
bhanna.alvine
Out of the box Revit has a 'branch connection-welded' family.
Set up your pipe type routing preferences to use Tap as the junction type and the branch connection as the junction.
Ope that helps you.
robk
Thank you for THE answer!!
