Pipe T-piece reducer marked on slope (at slope off)
ion_goteseanu
Message 1 of 12
ion_goteseanu
Good afternoon,
I have a problem drawing a different diameter from a T-piece. If I were to draw a T-piece from 110 to 75, it creates a slope (you can see it on the photo). The slope is turned off. I have also tried with other pipe types, but that doesn't work either. Do you have any experience solving this? That would be fantastic.
I suspect the problem lies with some settings. If I start another project, it works fine.
This is a project I have to take over...
Thank you in advance !!!
Replies (11)
Message 2 of 12
iainsavage
It looks like you have an eccentric reducer and its upside down?
It should be rotated so that the pipe has a level invert.
You maybe also want to look at your placement option for the pipe elevation:
Message 3 of 12
ion_goteseanu
I tried this, but that doesn't work either. The tube doesn't stay connected properly either.
Message 4 of 12
iainsavage
Upload the tee family please.
Message 5 of 12
ion_goteseanu
Hello, I just upload it.
It seems very strange. When I start a new project, it goes well; I suspect the problem stems from switching the piping.
Message 6 of 12
iainsavage
It seems to work okay for me.
When you first draw the smaller bore pipe the reducer is concentric by default.
If you then change the reducer to eccentric via the tick box in the tee family, the pipe elevation adjusts accordingly, with no slope.
If, for any reason, you want the branch to be level on top instead of level invert you can flip the eccentric reducer, again using the tick box in the tee family:
So, as far as I can see the family works okay.
You said "I suspect the problem stems from switching the piping" and I think you might be right.
Message 7 of 12
lauri_barnhart
Hello, @ion_goteseanu,
Just checking in—did the responses shared by @iainsavage help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
Message 8 of 12
Sefanja_Verkaik
Hello @ion_goteseanu,
The Problem you show in the screenshot is with the Reducer Revit family not with the Revit tee family because the T-Piece doesnt allow for different dimensions between DN1 and DN3. Probably best to contact trimble for your problem.
Kind regards
Message 9 of 12
iainsavage
"the T-Piece doesnt allow for different dimensions between DN1 and DN3"
Yes it does.
"The Problem you show in the screenshot is with the Reducer Revit family not with the Revit tee family"
The reducer is a component part of the tee family.
Message 10 of 12
Sefanja_Verkaik
Hello @iainsavage
I understand what you mean, but look at the first picture he has a problem with the 3rd connection not the 2nd.
In your picture you show the reducer for the 2nd connection which is there yes and it works. The 3rd connection reducers however is not build in the Revit family.
Message 11 of 12
iainsavage
In the family this is the third connection, controlled by R3  Connector parameter. Also conventionally the branch is designated as connector 3 (or C) on tee fittings. Hence my confusion about your statement.
You are correct that R2 Connector = R1 Connector via a formula in the family, but actually R2 Connector is not used and both of the straight through connectors use R1 Connector to determine the size. So yes Revit will insert a reducer at the connection.
My apologies for misunderstanding and causing confusion.
Message 12 of 12
iainsavage
In the tee fitting family you can select the nested reducer and edit it. Make it Shared and reload it into the tee family and the project.
You can now set this reducer as the default in the pipe's routing preferences.
When you then reduce the pipe size on the straight run the reducer in the straight downstream connector (what I would call connector 2) will behave in the same way as the one which inserts into the branch (connector 3).
