Pipe Sizing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys ![]()
First of all: I would like to say a big THANKS to all of you because I've learned lots of things from you.... This community is really good in my opinion!
Now it's the time to ask you another help...
I've got an issue when i want to use the magic "automatic pipe sizing" botton....
Let me explan better... maybe with an example:
I'm working in the UK and for Public Health we use different standard to design pipework for domestic water. (Standard BS 806-3-2006 Domestic Water)
We use Loading Units (LU) (Not Fixture Unit as Revit uses).
For my example I have:
3 wc => 1 LU x 3 = 3 LU
2 Sinks => 2 LU x 2 = 4 LU
4 Wash hand basin => 1 LU x 4 = 4 LU
So the total is 11 LU.
When I know the Loading Units then it's possible to have the flow rate from a chart. (So I can create an equetion: Flow Rate= f(LU) from Excel)...
When I know The flow rate then I can also use another Chart and see what is the correct pipe size for my flow rate. (see attached pic).
For my 3 wc the size for the pipe should be 15Ømm (flow rate 0.24 l/s)
then the pipe for 3 wc + 2 Sinks should be 22Ømm (flow rate 0.34 l/s)
then the main pipe for 3wc + 2 Sinks + 1 WHB should be 22Ømm (flow rate 0.42 l/s).
Now.... I know that Revit performs a general conversion from fixture units to flow, using the values found in the 2006 International Plumbing Code (IPC), Table E103.3 (3). But is there any way to use my own eqations to sizing pipes?
I know that I could convert Loading Units to Fixture Units (I did it) but Revit Doesn't use the same charts (Flow rate => pipe size ) that we use in the UK. (see attached pic)
So I must use an equation again.... I guess...
my question is:
How can Revit could understand my equations? What I have to do?.... Put my equations in some parameters or create a macro? I really don't know what I have to do...
I've seen lot of people who have asked the same question... for example here:
http://forums.autodesk.com/t5/revit-mep/fixture-units-vs-flow/td-p/4302974
... but i can't find a solution....
Please.... give a me hand....
Thanks guysssss!!!!
have a good day.
