Pipe size missing
Pipe size missing
不适用
5,901 次查看
5 条回复
1 条消息(共 6 条)
Pipe size missing
不适用
I am in need of creating a 5/8" dia. pipe (for refrigerant piping), however it is not in my list. It jumps from 1/2" to 3/4"...no 5/8".
I have gone to Manage > MEP Settings > Pipe Settings > Sizes and created a New Size (5/8")...it shows there in the Settings but still not in my drop down.  Am I missing something here?
Thanks!
0 个赞
已接受的解答 (1)
5,902 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
不适用
已接受的解答
Found my own answer. Revit, being as matter-of-fact as it is...I was missing changing the Copper pipe from "Brazing" to "Soldered".
Always something simple in the haystack!
0 个赞
3 条消息(共 6 条)
不适用
I have the exact same problem, however even I choose the correct new type called Storm drain, still does not let me use the new size.
does anyone knows the answer?
0 个赞
4 条消息(共 6 条)
dennis
My quick stab at this:
1) Check your MEP settings, Mechanical, then the Pipe sizes list.  Add 5/8 if not already listed.
2) Check Project Units, set to the fraction 1/8 or smaller (maybe it needs to be evenly divisible into 1/8: 1/16, 1/32, etc)
0 个赞
5 条消息(共 6 条)
BramJ
The basic issue is that you go from editing Type Properties to the Routing Preferences to the Mechanical Settings and you're no longer editing the correct type because the Segment: list isn't automatically linked to the type you where previously editing and this is confusing and bad user interface design for that matter.
6 条消息(共 6 条)
brock.johnston
In order to select a 5/8" pipe size in your drop-down menu, you need to choose 5/8" for a minimum pipe size in your routing preferences.
