Pipe Flange Rotating Incorrectly
I've built a flange. When routing with a Pipe Type that specifies that flange in routing preferences, it comes in as expected. If you add a flange manually, it comes in rotated 90 degrees. See attached pic.
Resolved. The forum keeps removing my attached RFA, but see below; family is built from the Ref. Level upwards, with "fitting" pipe connectors on the top and bottom.
I had the 2 connectors linked but had to assign the bottom one as primary. Not sure why it worked or how that would cause the error from above, but it worked. Good luck, friends.
