Message 1 of 11
10:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, I need your help for the following reason:
in the current project I need to model the FS system and specifically for the reducing tee I have 2 different types:
A. Mechanical bolted branch
B. Grooved tee
the type A connects 100/150 mm pipes to 15/50 mm branch pipe
The type B connects 100/150 mm pipes to 65+ mm branch pipe
I have attached the routing preference.
The question is how can I set it in order to model the 2 fittings automatically, because in this case Revit uses only one type, the first it finds. I tried also to modify the 2 families, leaving on the lookup table the diameters I want but Revit create a Custom fitting.
Manu
