Pipe connector in family to be same diameter as pipe
Hi all,
I'm creating a simple valve box family, and I'm trying to get the pipes to connect to the sides of the box however I can't get the connector to change size and match the diameter of pipe I connect into it, it keeps adding in a transition/reducer which I don't want. What parameter does the connector diameter need to be mapped to in order for it to read the pipe size that's connecting into it? Is it also possible to have it switch sizes after it's connected to match a pipe size change? I have the pipe connectors currently set to fitting, and have it mapped to a parameter I created called Nominal Diameter, but the connectors don't switch sizes automatically. I've attached the rfa below. Thanks in advance
