Pipe branching collars
Sæmorr
Message 1 of 9
Sæmorr
I'm looking for the Revit model of this type of pipe connector, adapter, collar, branch or derivation. It's used for water supply. Is there any family available?
http://www.vhm.fr/VHM-GB/VHM-CANA/PRODUITS-ADDUCTION-008.html
Replies (8)
Message 2 of 9
You can try creating it yourself if you can't find it anywhere.  It doesn't look complicated.
Message 3 of 9
L.Maas
I would use a simple tee or tap for the model and then use a detail drawing to show the actual model
Louis
Please mention Revit version, especially when uploading Revit files.
Message 4 of 9
Sæmorr
The problem with the Tee is that it has the same diameter on all connections. Doesn't look realistic on 3D. Probably I need to add some kind of adapter.
Message 5 of 9
L.Maas
Depends on the libraries you have installed. For example I have used the "Tee Branch Reduced - Threaded - GMI.rfa" from the Revit 2016 UK library
(\UK\Pipe\Fittings\BS 143 Galvanised Malleable Iron\Threaded)
Most of the time I would take a simple one from the library and modify it to my needs or create my own from sratch.
Louis
Message 6 of 9
fabiosato
You should choose a family that supports different sizes.
Unfortunatelly, I can´t tell which one will be OK, I use my own families.
Fábio Sato
Message 7 of 9
I guess it's a bit more complicated than I predicted.
Message 8 of 9
Sæmorr
Really nice job. How much time did it take you?
Message 9 of 9
Thank you.  It took about an hour, but I was also watching an episode of the x-files while creating it.  It's not perfect and needs some refinement if I was to actually use the family.
