Pipe Accessory Annotation Scale & Model Lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've attached a family where I was modifying a plan symbol into it because it previously did not have one. For the life of me I CANNOT figure out why in the family the model lines show up where I want them but upon insertion into a project the entire symbol is shifted to the right almost the entire length of the family... Any suggestions on my problem would help please & thank you. I've attached the family below, it is in R17.
Reasoning & workarounds:
I am sifting through my company's library of "Content" cleaning it out & recreating/modifying families as needed to create some sort of drafting standards. I've made it to Pipe Accessories & valves specifically. Narrowed 250ish families down to 44 that will cover everything our modeling scope involves & I am implementing standard symbols into them based on the symbols in our cad mechanical block.
I'm unsure of how others workarounds with these families are but we intended our 1/8" drawings to use single line pipe graphics for pipe, fittings, & accessories... So the idea is to use revit's default 'Use Annotation Scale' parameter associated to the model lines representing our symbol in plan & do the same with model lines in elevation (but set to medium view only) to cover us if we ever need elevations for single line piping while plan & iso/3D would use the ref/plan level model line symbol in coarse for those views. That is our workaround in order to see the "symbol" in plan/iso/elevation views along our single line piping, it also overcomes the sloped piping issue we see with symbolic lines or nested generic annotations.
