Revit MEP Forum
Pattern visibility in the MEP Pipework tag
2 REPLIES 2
347 Views, 2 Replies
Hi there,
Wondering if there is a way to change the pattern visibility in the MEP Pipework tag, depending on the pipe's parameter boolean value?
Let's say our pipe parameter boolean value is "Yes" - grey solid pattern in the tag is visible, if "No" - invisible.
Any ideas?
Thanks.
2 REPLIES 2
No. You can only change the color of the label, but not anything else. Create different tag types and use them for different scenario.
in reply to: ToanDN
Thank you for your feedback. Cheers!
