PARAMETER HIDE OR VALUE SET TO 0
mihir_shah
mihir_shah
Good morning All,
Attached is multilayer tray support. plan to extract MTO/schedule from it.
- all parameters are shared and tray arms are hide based on visibility.
is there any way to make length of arm 0 if visibility of that ARM is set as hide.
HermanSolomon
Hi mihir_shah,
Nice family 🙂 Yes, there is a way to control the Arm visibility. If you add the following formula into the 1-left_from_Bottom Formula Column, The arm length can be controlled. An explanation of the formula would be: if([1st from base] <IS ON>, Length=1200, <IS OFF><Length=0>)
http://revitrecess.blogspot.com/
mihir_shah
thx a lot.
one more help.
in place of 1200 constant is it possible to get instance parameter length from property bar.
HermanSolomon
Yes it is possible. However, the first thing you will need to do, is to change your parameter naming convention. Adding the text "1-Left" as a parameter name will cause Revit to see the dash as a minus sign, when used in a formula.
In the image below I have replaced the dash with an underscore. I have also created a driving parameter called 1_Left User Dimension. This parameter will drive the 1_Left From Bottom parameter.
The results can be seen below.
mihir_shah
thx once again
yes I did it and it is coming perfect...
cheers
