Panel Schedule Formatting for Single Phase Panel
Im having trouble fixing my panel schedule template for single phase panels.  Currently, the schedule is showing loads in the shaded cells.  I need them to only be shown in the clear cells. This is working fine with 3 phase panels.  Im just having trouble with this for single phase panels.
Also, I dont think the phase currents are calculating correctly.  Could someone help me with this please?  Thanks!
fabiosato
Just one doubt, how can you connect two phase loads into a single phase panel?
If you can share a file only with the panel and the loads I can try to check the panel template.
Fábio Sato
Nathan_Lamb
Community Visitor
Community Visitor
I know this is old, but for the sake of anyone else coming across this post, "two phase" isn't a thing. There is a difference between "phase" and "pole." The loads can be single-phase, but still be two pole loads.
cschroer
There was a recent post that had the same question --> https://forums.autodesk.com/t5/revit-mep-forum/how-to-make-single-phase-panel-schedule-show-every-ot...
Let me know if you need any additional help.
