I was wondering if there is a way to reorder the columns in the circuit table. Our standard is to have the description on the inside of the table (see below). I'm guessing that it is a no but just wanted to confirm.
Solved by tim.ingle. Go to Solution.
Unfortunately, I do not believe it is possible to configure a Revit Panelboard Schedule as you have detailed. You can shift the columns of trip rating / circuit breaker rating, number of poles, and Load Name / circuit description, but from my tests you cannot add or adjust columns inside or to the right of the load columns as the settings that control those columns can be found in the Set Template Options under the Circuit Table sub-options and appear to lock the way these cells appear. I've attached a couple images for reference.
