Overlapping of Text (from linked cad) to MEP Revit model
Text from Linked CAD overlapping with Revit MEP components and its getting printed as same.
Any recommended solution to make CAD link as background?
There is one option in the properties bar when you select the Link CAD.
Set the Draw Layer as background. Hope it will solve the problem.
@Anonymous I have given the snap from Revit-2019 only. It is not showing in your file may happen because when the CAD file was linked the "current view only" box was not checked. If you unchecked the box while linking the CAD file then to make the CAD foreground or background option will not show. You have to link the CAD file by checking the "current view only" option to make the CAD file foreground or background.
Great, Thanks for sharing, Its working now. @Anonymous
