Outer edge contour line thickness
rnarasimhan24U9N
Message 1 of 11
rnarasimhan24U9N
Hi all,
In 2D views of a generic model family, how do I show the outer profile (contour) as thick line and show all the interior lines as thin lines?
Right now, if I change the line thickness all the lines in the generic model changes.
-Ranga
Replies (10)
Message 2 of 11
iainsavage
In the family create sub-categories and assign different ones to each element in the family.
Message 3 of 11
rnarasimhan24U9N
Thanks for reply. I should have been more clear. My question is slightly different.
In 2D view, I have (front / side) views of 3D generic model family. I want to see the outlines as thick and inner lines as thin. How do I get this result? I cant assign using the technique mentioned above because, the full 3d object is selected not just outlines.
Message 4 of 11
iainsavage
This is a section view in a project.
You can control line thickness separately for each sub-category.
I thought that was what you meant - yes/no?
Message 5 of 11
rnarasimhan24U9N
Your concept is correct. But that does not work for me when I tried. Does Revit recognize the words "Interior" and "Outline" as inner and outer edges?
-Ranga
Message 6 of 11
rnarasimhan24U9N
Please see the below pictures. first one is what I have. second one is what I intend to see.
Message 7 of 11
Not sure if this will help.
Message 8 of 11
rnarasimhan24U9N
@ToanDN , Thanks. But this did not help.
Message 9 of 11
iainsavage
In part 6 are those images 3D geometry or are they 2D linework?
Message 10 of 11
iainsavage
In the family you can use lines to trace around the outlines in relevant views and apply the sub-categories to the lines.
Would that work for you?
Message 11 of 11
rnarasimhan24U9N
Hi @iainsavage ,
They are 3D generic models. And I cannot manually trace the outlines. Way too much work.
If there is no setting for this in Revit, I'll close this topic. May be silhouettes option is the closest to what I need.
-Ranga
