I am facing a strange issue here. All objects under pipes are being masked or not visible in hidden line mode. Same is happening with plumbing fixtures situated under overhead pipes. I am attaching 2 snaps to explain the same. First where red pipe is masked by blue. In second snap, its visible as blue pipe is deleted. Blue one is positioned above red.
I am working on plumbing in architectural template using revit 2021. I am aware of wrong discipline template being selected, but can't rectify at this stage. So any help will be highly appreciated.
A newbie in Revit MEP.๐
Solved by RobDraw. Go to Solution.
@ wrote:I am facing a strange issue here. All objects under pipes are being masked or not visible in hidden line mode. Same is happening with plumbing fixtures situated under overhead pipes.
That is normal for hidden line view. Hidden = not visible. If you want to see the the hidden lines, change to wire frame.
If you need hidden line visual style, then have a look at MEP Hidden Line gap settings.
