New visibility parameters off by default?
jason.bowman
Message 1 of 10
jason.bowman
I have multiple family types, we're talking 20 and I have Yes/No visibility parameters on each one specified as "Type" not instance - however when I had a new visibility type, it checks all of the existing ones as visible too, I want them all to be invisible so I just just select the one I want - going through and unchecking every one each time I want to make a new one isn't time effective and the more I add the longer it gets. Marking the elements as invisible before I create the type parameter and apply it also doesn't work.
Replies (9)
Message 2 of 10
RobDraw
It's probably hard coded and not open for change.
Rob
Message 3 of 10
jason.bowman
Ridiculous if it is
Message 4 of 10
RobDraw
In this forum, it is the way it is.
You can express your disdain in Product Feedback or make a suggestion in the IDEAS forum.
Rob
Message 5 of 10
RLY_15
Option 1 - when you make the new parameter, set the value to false in the formula field so that it applies to all Types, then remove the formula.
Option 2 -
Each type you create a Type that requires new visibility control, you add a Y/N parameter, assign it to the element, add the formula, and tick up the integer for that Type.
Message 6 of 10
L.Maas
What I normally do is the following
-In the family editor I create the different types.
-I add visibility parameter(s).
-I add a formula 1=0 (to each visibility parameter) if I want them all off.
 If you now go through the different types they are all off.
-Remove the formula and start setting them as desired.
Other option is to make use of a type catalog. I normally do this when I have more than 5 types.
You can prepare the type catalog in other software (e.g. Excel) and then use that software copy/paste (or formulas) functions.
With this method I have made families of more than 100 types.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 7 of 10
iainsavage
If you have 20+ types in one family, I would recommend using a type catalogue or lookup table and you can pre-populate the yes/no parameter values with 0 or 1.
Its far easier to manage changes in an external txt/csv file than scrolling through so many types in the family editor.
Message 8 of 10
jason.bowman
For context, this isn't a pipe fitting family, its an annotation family that contains different types to detail different pipe support arrangements on our drawing sheets - so the families are built up of lines and text so not sure if I can use a catalog for it?
Message 9 of 10
jason.bowman
The method of =1=10 works for what I need - hopefully they add the ability to do this quicker in a later version.
Thanks for the help!
Message 10 of 10
EAydinMVSM4
i had the same question and just came across a potential solution. If you duplicate another visibility parameter that's turned off, it remains off through ALL the types. It's a lot quicker to turn it on for specific types, than to turn it off through all.
