Revit MEP Forum
New Architect Model in new location
5 REPLIES 5
Nick-H
432 Views, 5 Replies
I have done a full MEP model with the architectural linked in and aqquired co-ordinates.
but now we have a duplicate building but in a different location.
I have tried linking the MEP into the new location then publishing the co-ord to the MEP model, then in the MEP model changing to the new location and it throws everything out. HELP! I dont want to have re-model everything when its just a duplicate in a new location.
how do I change the co-ordinates without having to move the model??
5 REPLIES 5
Revit_Whisperer
in reply to: Nick-H
You can copy the original linked model to a new location for the second building in your model.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Nick-H
in reply to: Revit_Whisperer
the MEP is not lined, it is only the architectural that is linked, which is in a different location in the new project
stever66
in reply to: Nick-H
Can you make a new revit file, and link your MEP model into it twice?
Nick-H
in reply to: stever66
but ive created sheets in the mep model and tags on the sheets etc..that i want to keep
in reply to: Nick-H
- Save as your MEP model (A) to a new file (B)
- Open (B) and delete all model elements, keep Sheets and Views intact
- Link (B) back in (A), one instance (A1) Origin to Origin, anther instance (A2) wherever it is supposed to be
- Open the views where the (A1) shows, VV, link tab, ex[and the link tree and set the (A1) link instance to by Linked view.  There, all the existing graphics and annotation you have created in (A) will show correctly.
- Duplicate views to show (A2) link instance then you will have them all with very minimum work.
