Need Help in Pipe Fitting Modification
Hi, I'm a beginer to lookup tables.. here I'm trying to create a custom pipe fitting that matches to the organisation standard.. i believe that i have linked the lookup tables properly to the pipe fitting.. I tested the parameters of the fitting and it changes properly in the family environment. so then i loaded the family in to the projet to test it with pipes. when i place the fitting on a pipe, the former one automatically asdjust itself to match the pipe size.. untill now there are No issuesSmiley Wink But when i try to change the pipe size along with the fitting in th eoptions bar (by tab selecting it), only the pipe size changes and the fitting doesn't change. it forms a erducer at the end..
i have attached the files for reference.. Please guide where does the mistake happen.
danielkazado
  Delete the formula for Nominal Radius (default)  parameter
  Write the formula   Nominal Radius * 2     for the  Nominal Diameter (default) parameter
  As the fitting connection uses Radius it works when you change pipe and fitting diameter same time.
  Hope helps.
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
Thanks a Lot DanielSmiley Happy you saved my day..  it worked fine.
