I have the attached make-up air unit and it works fine in my duct system for pressure drop and flow calcs. the problem is, the unit has 3 options to discharge air (actually 5, but i only use 3). it can discharge on top, bottom or the end. In any given design only one of the options is used. Instead of creating 3 different families, I want to use one family, and just cap the unused duct connectors.
but the only way my duct system works if I manually assign the intake connector to use one of the 3 flowrates (make both discharge and intake connector to be the same parameter). if i make them separate parameters, the duct system and pressure doesn't go through the unit.
I tried to make the intake a separate parameter and use an if-function to determine he flow. it works in a way that only the used discharge connector provides the flow to the intake connector. but it doesn't work in the system.
In my case there is a louver and some ductwork to the unit. And then more ductwork from the unit to the diffusers. If I manually assign the actually used discharge connector and the intake connector the same parameter, the system inspector correctly shows the entire duct system up and downstream of this unit and system pressuredrop is 0.39 in. If i do one of my automatic ways (the if-function etc.), the system inspector only shows from louver to this unit and pressuredrop is 0.06 in only.
How can I set the connectors in this family that I could use any of them? Or is this impossible and I'm condemned to use separate families for top, bottom, and end-discharge (the unit also has the option to discharge right and left side, I doubt I will need that)
I ran into similar issues a while back for piping and the problem is that Revit doesn't have a yes/no option for duct or pipe connections.
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
