Moving a working floor plan to different discipline
I'm drawing hydronic piping in Revit 2017.  I opened Revit this morning, and could not locate the level 4 drawing i've been working on, found it in the plumbing discipline.  I don't know how it got moved, i could've done it unintentionally, but I'm pretty sure I didn't.
I would like to know how it happened, but more importantly, I would like to know if it's possible to just move it back to it's original location in the Hydronic floor plans.
This is a screenshot of the working floor plans folder.  The "Level 4-moved" in the plumbing discipline is the drawing that was somehow moved.  The "Level 4" is a copy I made so I could continue working for now.
Thank you!
Highlight the view(s) and change Discipline from the Properties.
RobDraw
How it happened is at the user level.
As @ToanDN already said, just change the discipline/sub-discipline as needed plus any other internal guidelines that may be in place for view template setting etc. that may have also changed in the process.
Rob
as much as i hate to admit it, it probably was something i did.  i'm still going to blame revit though!
thank you sir!  nothing like an easy fix to make you feel dumb
