Revit MEP Forum
Motor Control Center "MCC"
8 REPLIES 8
Message 1 of 9
2701 Views, 8 Replies
I am using REVIT MEP 2013 and we have a project that the motors are to be connected to a MCC (4 Sections). The MCC that i used came from Autodesk Seek, 480v, 3 phase. I was able to circuit one motor to the MCC, but when i tried to connect another motor to the MCC the MCC does not appear under the Distribution System, this is when i pick the "select panel".
How can i circuit my motors to the MCC and make the 4 Sections to just one MCC.
Thank you for your input.
Jnuguid
8 REPLIES 8
Message 2 of 9
vsrkk2005
hi
If you are adding one more motor to the MCC at first you increase the no of poles inside the MCC.
And if you need 4 sections in MCC, you need to give parameters in the family number of vertical rows.
i am giving just my idea, if not correct please tell me.
thanks
siva kumar
Message 3 of 9
Thank you very much for your attention, I try these.
Jose (Jun) Nuguid Jr.
Technical Engineering Section
SFPUC - Engineering Management Bureau
(415) 551-4899
jnuguid@sfwater.org
Message 4 of 9
i was switch to do another project, that is why i was not able to get back to you.
Once i try the recommendation i'll get back to you.
Thanks and i appreciate your concern.
Message 5 of 9
fabiosato
Just change the Max#1 Breaker Poles parameter to a bigger number. For 4 loads 12 will be enough!
Fábio Sato
Message 6 of 9
thanks for your help, it works
Message 7 of 9
in reply to: vsrkk2005
thanks, i increased the # of poles and it works
Message 8 of 9
You give such a nice information.. It is too good to study for same subject.. Thanx
Electrical control panel manufacturers
Message 9 of 9
Can you please tell me types of mcc panel
