04:21 PM
- Mute
- Permalink
- Report
I am not entirely sure if i'm posting in the right spot.
I was trying to model MCCs into my model. I will have about 18 MCCs roughly in the plant that we are designing. I looked at the built in family for MCCs and it looks like it is set up as a block per section of the MCC. My end goal is to connect all the loads including VFDs, motors, and other equipment using VFD, starters and circuit breaker configuration. Is there a way to connect each block together so that for example 14 blocks makes one MCC. I need to output a MCC schedule that shows all the connections and what type of starter they have.
I am using Revit 2016 MEP.
Many thanks!
