Show only
Search instead for
I made the mistake of starting a new model as a template file. Is there a way to change this to a model and not a template? I tried making a new model and copying my things over but the walls, coliumns etc will not copy over.
Create a new project, select your template file as the template, and all of the elements should carry over. Using Revit MEP 2012.
Corey D. ────────────────────────────────────────────────────────────────────── ⁞|⁞ Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
