Missing options for light fixtures: vertical face/plan/work plane.
不适用
4,440 次查看
9 条回复
1 条消息(共 10 条)
不适用
I'm adding a continuous linear fixture up a wall, across a ceiling, and down another wall. When I go to place the fixture Revit v2017 doesn't give me the option to choose between vertical face/plane/work plane. I have to place it on the associated level and change the elevation to get it into the ceiling. What am I missing in my family that isn't allowing me to choose what I place it on?
Thanks in advance,
-P
0 个赞
已接受的解答 (1)
4,441 次查看
9 条回复
回复 (9)
2 条消息(共 10 条)
RobDraw
You are using a non-hosted family.
Rob
3 条消息(共 10 条)
Scott_D_
If you check the family settings it should be a Face Hosted type, this can be attached to anything.
If you have a Face Based family and are working in Plan it will try and attach to the floor, you need to work in an RCP to attach to the ceiling.
4 条消息(共 10 条)
fabiosato
已接受的解答
If your family is on-hosted, you can check Workplane Based, then your family will be possible to place in any plan. May solve your problem.
Fábio Sato
5 条消息(共 10 条)
sara
Hi all,
What I see is a "Face" hosted light in the family editor, is missing some of the other attributes found in the Light Fixture Family Template. Namely: Work Plane-Based and Always Vertical.
Is there a workflow to retrieve this? (Other than rebuild?) and is this evidence the family was started under a different category?Light Fam Cat Settings.pngLight Fam Template.png
Thanks so much!
0 个赞
6 条消息(共 10 条)
Create it from a Generic template with the host of your choosing then change the category to Light Fixture.
0 个赞
7 条消息(共 10 条)
sara
AH! Yes. The Manufacturer created the family starting with a Generic family, which does not have those features.
0 个赞
8 条消息(共 10 条)
I think you misunderstood my point. A face based family does not have Work-plane Based and Always Vertical tick boxes. Period. It does not matter if the family is Generic or Lighting Fixture or anything else.
To get those two boxes, you need to create the family from the Generic Model family template, then change it to Lighting Fixture category from the same dialog.
9 条消息(共 10 条)
sara
Period! Period. 😉
I will bring the light fixture into a light fixture template. Seen below:
These are the options in a Generic Face-Base family.
My query was how to get the workplane hosted and always vertical options. I have brought the light into a Light Fixture template. Rocking and rolling. Thank you,
0 个赞
10 条消息(共 10 条)
Good. Actually my statement earlier is not entirely correct but it does
not matter now.
0 个赞
