Missing grid circles in inked model
AdamNorfolk
AdamNorfolk
Hi, I have encountered model issue I can't overcome. I work on MEP model with linked architectural model. On the linked one all grid  circles are shown.
when linked to MEP  the bottom and right hand ones are missing.
I would like to show them all on MEP drawings as they appear on the arch model.
Thanks in advance.
You could set the link to display by linked view and the grids will show as in the link view. Then change to custom to set the rest of the link to fit your need.
Another way is to copy monitor grids to your model and you can configure them however you want.
AdamNorfolk
Thanks.  I should have started with copying grids from the linked model. I think it's a good practice for the future. To justify my laziness I could only say the MEP model I created initially suppose to be just a few elements which I have been asked to do, so did not bother with grids. Then the MEP evolved in full size blown model with ducts, containment, pipework, builders work etc. The method with 'by linked view' it's not an option in my case as the arch model has too many elements not required in my view  and it would be far too much time to switch them off. Thanks ToanDN.
