- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi I am working on Plumbing of a 30 story building. 15 of those sotories are exactly the same and I have modeled only one of them in order to copy the rest of them in the exact same place in the above floors. This has several issues (see below)... if anybody comes up with a better solution i will be happy to discuss it.
- All plumbing fixtures are monitored from an ARCH rvt file. If systems are copied then plumbing fixtures are copied to meaning i am only monitoring one floor and not the rest of them even if they are the same. Otherwise fixtures will be doubled in the very exact same place.
- MEP and groups are not good friends, then gourping is not recommended.. should I copy every element in the system and the reconnect it to the mail system? This seems quite manual and tedious.
- When copying elements that are part of the system (eg heater or toilet) they need to be rehosted in every single level manually..
H
ave been tsrugginlin arround with MEP and coordination lately.. would appreciate if you could recommend online courses or good websites. I will promess to update my blog with everything i ve learned lately soon 🙂
