Material changed not like the image
pe_simon
pe_simon
I have changed the element rectangle to "Gold" material, but in  "Realistic" view, it didn't shown the "Brass- Polished" look like the image. Why? I am using Revit 2020. Thanks.
It will look like the preview when you render the view.
pe_simon
How to set it like the image material?
Reflective materials will never look like their appearance preview in realistic visual style.  You need to render the scene, or use matte materials instead.
!Dalton_Goodwin!
@pe_simon You would need to render the view if you would like that level of detail. The rendering engine is more powerful at processing more information such as reflections and lighting. you may want to consider using Twinmotion or Enscape if you want a rendered view to fly around in.
