Firstly, I changed the Branch panelboard template. Now, I need the default panelboard to create a new/different look for our panel.
How do I restore the default panel board template in the project I am almost finished with. I have tried transferring propers, but only one of my panelboards change. When I try to change the rest to the default, I becomes the changed default, panel board.
Solved by mthomas45. Go to Solution.
It sounds like you've overwritten the default template in your project. Rename the template you modified to something else. Then open the default electrical template and go to Transfer Project Standards. Select the panel template option and transfer it into your project. Then you should have both available.
Here I sm bragging on my Revit skills and get stumped by the old overwritten branch panel mess! LOL thanks for the assist, took care of my issues.
