LOOKUP TABLE
LOOKUP TABLE
LOOKUP TABLE
i want to know how to edit in look up table for pipes or pipe fitting?
If it is an external lookup table, it will be an .csv file and you can edit it in excel.
i need to know the path of this files
They would be located in the file structure for the family. If the lookup table is loaded in the family you can find the file location looking under the parameter dialog box.
sujanc
You can also get the .csv file from the below location and edit as per your requirement.
"C:\ProgramData\Autodesk\RVT 2019\Lookup Tables\Pipe"
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
