- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I've been using a lookup table to provide part names on some of the content I generate for the company I work for. I've used this formula dozens of times now (Or similar method). Occasionally Revit will throw this error;
You can see in the screenshot above that the formula actually works. Alternate Description is being populated with the correct info. This error only gets thrown when "OK"ing out of the part, or changing the Type Name dropdown to a different size.
"Alternate Description" is a TEXT field. ND1,2,3 are all instanced based. The Lookup Table loads with no errors.
This happens about 25% of the time I use this lookup method to fill out a part name. I can't square out exactly what it doesn't like especially considering it's functioning until you click OK on the part. Usually the repair is so many random things I try until it works it finally just works.
This has been a major frustration I can't solve and push behind me, any help would be greatly appreciated!
