- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hello,
iam working on a central file with my engineering team, its a Plumbing model and i supposed to be the only one who is using this file, i used to work thru work sets all ownership by me for each system and so on, one day i have received and error that central file not allowing me to open local file again and showing the attached message, so the only solution i figured out is to detach the file from central and save it again as a central file,
then before i closed i relinquish all elements and work-sets to avoid the same issue
but from time to time keeps showing up
anyone can assets me how to stop this, maybe I'm doing something wrong with the workflow methodology while working on the local file
