Linking mechanical equipment models to specific schedules to auto-populate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello! I have a sheet on Revit containing many schedules for different types of VAVs. The VAVs are contained in families, each with their own schedule. (An example being a schedule for VAV terminal units w/ an electric coil and another VAV schedule for a hydraulic coil) I know you can populate schedules by changing the schedule number in the equipment property tab under identity data; however, I want to make it so that when a VAV is tagged or placed into the model it will automatically be added to the correct schedule instead of manually inputting the schedule number each time. Is that possible?
For some more context the sheet numbers and schedule numbers will not change. I am trying to make a master copy that can be imported to multiple models. In this case the sheet is labeled as 9 with the VAV terminal unit w/ electric coil being 9.01 and the other as 9.02. That's the general format
Thank you in advance!
